hob from revit library inserted above countertop is not shown in floor plan.
i can see it in section and 3d. when i insert a sink it is show above.
what is the issue with hubs?
please see images attached
thanks
check your family visibility setting or in the main plan create a plan region in the area of counter top and set the view range value or share your file so we can check. thanks
Is there masking region in the counter family? That would explain why the sink shows fine while the other two don't. When you have 2d symbolic, it will show up fine. So your best solution would be remove the masking region and use counter 3d object to show.
you can check inside the family the visibilty of it, by check it with Coarse. Medium and Fine it will apear in all view
