please guys bear with me, im new to revit and i´ve seen sheets where theres a regular floorplan view with all its details, and on the titleblock above the porject name, sheet number and etc theres an area where sometimes people place a small 3d view with the level show in the floorpaln highlighted and i dont know how to place this small highlited 3d view, i would gladly appreciate any help
Gelöst! Gehe zur Lösung
Gelöst von robert.klempau. Gehe zur Lösung
Hello @Anonymous,
Use the following steps to get your 3D view with specific levels on your sheet.
Note: Every time your model changes, you have to create new images and replace the old ones with the new images on your legends.
The reason why you have to use this method is of the fact that you can't place a 3D View on multiple sheets and legends you can.
I will upload a video where I show you how this works.
Hello @Anonymous,
As promised the Video about how to get the images on the sheets .
Hello @Anonymous,
Here is another Video where I show you how to update the images on the sheets.
Hello @Anonymous,
Great that I could help you.
Did you see the videos?
Would you be so kind to accept both videos as solutions so the will be seen by others as a solution?
