For the WF20 & WF30 - I would like not to show a length. I am unsure why WF20 does not show a value other than it has multiple instances and I am assuming Revit is not adding those instance together so it generates "blank". The WF30 does generate 112'-6" as a length value and I'm assuming it is showing because it is one instance.
I need both to be blank or "-". I do not want to show the total length the the footers. Is this possible?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You are correct why WF20 showing blank and WF30 show one instance length.
If you want to blank WF30, just add another WF30 with a different length (keep it in a different phase or workset), then you will get the blank cell because of multiple non identical instances.
