Hiding Section Box Lines
caleb.r.scott
caleb.r.scott
Hello!
Is there a way that I can hide the lines for section box? Or is there another good way to create this kind of isometric plan cut view?
Thanks!
isosa9APBT
Yes, if you right click on top of the section box line and select hide in view then elements, it will hide it, you can also hide it from the settings.
isosa9APBT
If you want to get the section box lines back when you use the right click way, you have to turn on hidden items with the light bulb at the bottom and repeat the same process but you tell it to unhide the element.
You can keep the Section Box category on and use pyRevit Section box toggle button.
caleb.r.scott
Oh great, thank you!!
caleb.r.scott
Thanks!!
