Hiding Element
Hiding Element
Message 1 of 8
Hiding Element
When i hide an element in a particular view by rt click .- hide element. It does hide ..How do make it visible when required?
Replies (7)
Message 2 of 8
click on "Reveal hidden elements"
and now the hidden elements in that tarticular view will be vissible select it and say unhide in view.
now switch back "Reveal hidden elements  "
Hope it helped
Message 3 of 8
It soved my issue....
Thanks for ur post..
Message 4 of 8
Hi Mr. Bhat,
Can u pls guide me as to in REVIT MEP can i make my walls as Ghost so that i can see plumbing pipes through them....walls are notindicated in the the model catagories...
Message 5 of 8
Are these walls placed in Revit MEP or from an linked file.
Have you tried using Phase, If not try using them.
Put the walls in the phase you desire and play with phase display in individual views.
try it out, in you have any problem I will write in more detail.
Message 6 of 8
Chris.Aquino
I would also make sure the view Discipline is set to something other than Architectural or Coordination.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
Message 7 of 8
Mr Bhat,
I shall still need to explore the basics of PHASING...any ways as of now ur post solved my issue...
thanks....
Message 8 of 8
Mr Bhat,
Thanks for ur post.
I have my architectural model linked to my Revit MEP one.....how can i control the visiblity of various things like beams , walls etc. as in switching on or off when required....
Any suggestions appreciated.
