I am working on a project which is going to have fused Glass reinforced plastic panels for the façade and I wanted to know if there is a way I can mimic the same using a curtain walls. I have a used a curtain wall system for a couple of reasons the first being I have a pattern of the façade which is split into modules thus I could not make a continues panel, secondly I needed to bound the rooms to the exterior wall.
what I have current in the model is a curtain wall system with a set panel size and the façade is shaped like a cuboid with rounded corners. I have attached a snapshot of one of the corners.
thank you in advance.
Gelöst! Gehe zur Lösung
Gelöst von Ilic.Andrej. Gehe zur Lösung
Modify/Linework/Invisible Lines .... select the curtain panel edges
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Alternatively, set a view override for Curtain Panels Projection Lines to be white.
Hey dr_Grozozo,
thank you very much for your assistance this worked fine.
hey David,
I tried your option as a quicker solution but the unfortunately I lose the pattern details as well of my curtain panel if you have a way to restrict the visual graphics settings just to the edges let me know.
thank your for your reply appreciate it.
Hi ToanDN,
They are suppose to be curved this I guess would have been my second query. I was reading online and watching tutorials which used an adaptive curtain panel family but I am not too familiar with them. it would be extremely helpful if I could get a few references of a previous discussion or tutorial to make the panels curved.
thank you very much.
