Hello ![]()
Is it possible to Hide the green Pivot in Revit?
Hi @Pantaleon02
I found this old post for the same issue with a suggestion, I don't know if this ever worked but worth a look:
https://forums.autodesk.com/t5/navisworks-api/hide-pivot/td-p/5410787
Let us know if it works.
Hello @markcalloway
I tried this suggestion but it didn't work
Do you know Is there a visibility option for the pivot inside of revit? ![]()
Hi @Pantaleon02
Sorry to hear that didn't work, off the top of my head I don't know of a setting but maybe someone else on the forum can help out if they have any ideas...
I see it when I orbit.
i'm trying to do a video (screen recording) about a building I made in revit, but the green pivot appears as always in the screen...
Is there a way to hide it?
I orbit a model in Revit and I see no such thing. Do you orbit a Revit model in Navisworks or something?
I forgot there was an orbit tool.
Yeah, if you use the tool you will see the pivot...you are out of luck.
Use Shift + Middle Mouse button, you don't see the pivot.
I'm using this little guy for zooming and for rotating my model in revit ![]()
I only noticed the green pivot when using it... So I was wandering how to hide it... or if it's even possible? ![]()
Bump.
This is the pivot symbol which appears when using the 3D Space mouse pictured above. Can this be removed as it is annoying to see this in the model?
