Hi all,
I have seen a number of posts related to subcategories.
I have a similiar problem. I have a received structural file with CLT timber beams.
Within the family (of the structural) file - the engineers have modelled a cross under the "structural framing [projection]" subcategory
I would like to filter out this cross, however because the cross is on a very generic subcategory - i do not want to hide / change this subcategory on a project level, i would like to control it on a view based level. (correct me if i'm wrong but changing the subcategory of the projection of structural framing to white lines / hidden would effectively hide these elements in their entirety - in a B&W view)
Trying to filter and use a solid hatch does not cover the symbolic lines.
I think this may result in requesting the engineers updating their family uptream to place these lines on a more specific workset we can control on a project level
Does anyone have any ideas if this is possible without the consultants amending their families ?
(one slightly protracted method I would like to avoid would be to copy monitor the beams and amend the family on our end to remove the offending cross- this seems a bad idea ...)
You can add those subcategories to your own model and then you can control it from a view template.
