HIDE ONLY LEVEL LINE
3 ANTWORTEN 3
Nachricht 1 von 4
504 Aufrufe, 3 Antworten
CAN I HIDE THIS LEVEL LINE?
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: Anonymous
@Anonymous
If it is just for that view, you can simply select the level >> Right click >> Hide in View >> Elements
If you want to hide certain levels on several views...you can create a view filter (which you could also add to the View Template if you wish)
  1. You can either use an existing built-in parameter of the Levels Category (Such as Building Story or Structural)
  2. Or you can use a custom/user created Project Parameter (Manage >> Project Parameters >> Add a new Instance parameter and assign it to the Category Level) - ex: a yes/no "Level Filter"
  3. Create a view Filter and use the yes/no project parameter you created in step 2
  4. Set the condition to equals: yes
  5. Go to the view >> type VV for visibility graphics and under Filters tab Add that filter
  6. Uncheck the box under visibility and Apply
  7. Select the levels you want to filter out/hide and in the properties box check/yes the parameter "Hide levels" which you added in step 2
  8. Uncheck the box under visibility
Level Parameter - Building StoryLevel Parameter - Building Story
Create a VIew Filter to Hide LevelsCreate a VIew Filter to Hide Levels
Visibility Graphics - Add the Hide Level FilterVisibility Graphics - Add the Hide Level Filter
Uncheck the box under visibilityUncheck the box under visibility
Nachricht 3 von 4
1. Crop it out of the View.
2. Hide it in the Views BY ELEMENT
Nachricht 4 von 4
Can you not switch the Levels to 2D extent and grip stretch the line?
