Hello experts!
I have a Revit file that is only set up for sheets with the building geometry and views coming from a linked file.
I need to hide one gridline that comes from the linked file and want it to be hidden in all the views that will be put on the sheets.
Can anyone think up a quick way to do so?
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von MichaelWarwick7522. Gehe zur Lösung
One idea is to turn off gridlines for the linked model in your view template, in your project copy/monitor the grids, with the exception of the one you never want to see.
That is what I would do.
