Hide Matchlines
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
DalskiSelecta
726 Aufrufe, 4 Antworten
Hide Matchlines
Noob question; how does one hide matchlines in a view template; cannot seem to find the appropriate menu?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: DalskiSelecta
...or a quickie way would be to select the Matchline and Hide In View.
Nachricht 3 von 5
DalskiSelecta
Thanks Barth, how does one do it in a view template? Want to apply it to the 150 odd plan views at once. Can't see a menu in the view template view & the filter view/ graphics menu is greyed out as a view template is being used.
Nachricht 4 von 5
View VGOs are inaccessible (e.g. grayed out) because a View Template is in control of them.  You need to modify the actual View Template that is assigned to the View.  You do this through Manage View Templates under View Templates on the View Tab.
Nachricht 5 von 5
Click Edit VG override annotation.
