I want to have an outline on a title block sheet template so show where the boundaries of the sheet is, but I dont want these lines to be visible as a border in the finished pdf. Tried doing it with a reference line, but thats not visible when the title block is loaded into the project. Any ideas?
Using Invisible Lines linetype you can achieve this. When you hover with the mouse over the titleblock you can see the actual invisible line border.
when you taking printout use this option in print setup its helpful to you..
