I am creating separate schedule for different level using filter of level, and put it together with the associate plan, so I don't need the schedule to show " level" . But if I remove level from the field, then all the rooms from different levels will show up. Since I am not putting room numbers yet, I don't know what other filter I can use except "level"
Gelöst! Gehe zur Lösung
Gelöst von mhiserZFHXS. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Select the level column and hide it.
Can also be done here (and unhidden if you need to do that at some point).
