Hey
I have created a Multi-Category Tag that aligns with our Door Hardware Shared Parameters. The Multi-Cat Tag Family has formulas applied to show an abbreviation when selected on a particular Door in the project. Worked great until I realized that when the box is unchecked, the text border of the label/text remains. Any ideas on how to remove this border? The border is required and I want to avoid a visibility parameter for the box since the text border is always consistent with the text in terms of width. It is a single Tag with 2 Labels assigned (each having its own SP) and I was also looking to avoid making a separate Tag for each case. This is only required for certain Door Hardware.
Define a Family Type that has that Label invisible and use that Family Type in those instances where that Label is not needed.
Yeah I definitely thought of that and tried it out. However, that would involve an extra step which I would love to avoid, but I realize may not be doable. I wanted to keep it very simple; you check the box and the abbreviation appears. It works great if the border is not on, so I will try convince my team to remove the border altogether.
Yah, unfortunately Tags and Instance Parameters don't mix in Revit. Maybe someday though. In the mean time, Family Types...or no box, like you said.
