Hide elements in linked files - permanent
3 ANTWORTEN 3
Nachricht 1 von 4
mairh_tsek
1054 Aufrufe, 3 Antworten
Hello all,
In the Revit model I have linked some .rvt files, and I have hidden some elements ( click on the element > right click > hide element). I have noticed that each time that I Reload from the link files in order to acquire the latest version the elements that I had hidden appear again
Is there any way to keep the elements of the linked files always hidden ?
Thank you in advance!
3 ANTWORTEN 3
Nachricht 2 von 4
stevie_kelly
als Antwort auf: mairh_tsek
You could use a filter to turn visibility off for certain elements, then when you reload the link, the filter will still apply.
Nachricht 3 von 4
als Antwort auf: stevie_kelly
Or place them on a workset that you can turn off.
Nachricht 4 von 4
RobDraw
Hide by element in a linked file is only reliable if that element doesn't change. If it changes, it is a different element and therefor will show.
Rob
