Hide dwg file on plan
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
2018 Aufrufe, 6 Antworten
there is another method to hide the dwg file on plan beyond to use hide or isolate command down the screen?
Thank's
6 ANTWORTEN 6
Nachricht 2 von 7
Sahay_R
als Antwort auf: Anonymous
Go to Manage>>Manage Links.
Under the Imported Objects tab you can unload the dwg
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 7
als Antwort auf: Sahay_R
Hello @Sahay_R is not load but is there anyway
Nachricht 4 von 7
CLICK VG it´s a shortcut to open grafic visibility , the box will open , click the tab imported categories , it will open the list of imported DWG for the plan , you can select or unselect it , also can click over + and unselec only what you dont need to see to , you will have a cleaner picture of dwg drawing
Hope it helps you ,
Nachricht 5 von 7
I have noticed too that the "unload" function does not always work. I've had several instances where I unloaded the CAD drawing but it would still show up in my views.
Nachricht 6 von 7
@Anonymous it's my case
@Anonymous thank's very much!
Nachricht 7 von 7
You are welcome !!!
