I know I can use a unicode separator character to give a blank dimension but we often dimension window schedules to the inside of the reveals and use a secondary witness line to further indicate this is the case.
Obviously doing a bunch of modifications on multiple dimension lines to hide the small reveal thicknesses takes time when you have dozens of windows. It would be nice to know if there was a way to use a formula in the dimension tools rounding box, or any other method of hiding dimensions less than ~20mm without affecting the main dimension.
pretty unique query..
On the other hand, have you tried dimensioning entire wall, with options
of opening, wall and grid intersection... takes a click to get these dimensions..
dimensioning correctly and picking elements required seems right way to do it...
Dimension option
@Corsten.Au wrote:pretty unique query..
Those dimension settings aren't available in an elevation. I tried it on a plan and it doesn't pick up the inside jambs. I could rebuild the window family/s to have the reveal line up with the opening, but it still doesn't easily let us output the double dimension at the reveal without all the fussing around we do now.
