Hide / Delete Project Property Parameter
2 ANTWORTEN 2
Nachricht 1 von 3
698 Aufrufe, 2 Antworten
Long story short: I am testing out Revit with the Autodesk Forge Viewer and I want to (because of the UI) customize the Properties Parameter Data, and create my own Groups (categories) and Instances. This is why I want to delete or hide these parameters..
Kindly see attached photo for an illustration related to which parameters I want to hide/delete (Constraints, Construction, etc..)
Is this possible?
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: Anonymous
No, these groupings are hardcoded. Which groups will show up depends on the objects selected. If the modeller of the families has added parameters to a certain group it will show up. The identity group will always show up because all families will have (fixed) parameters under that  group.
If you edit a family and create a new parameter you can choose to which group (fixed list) that parameter will belong.
If you want to use different groups (from the fixed list) you will have to edit all the relevant families and edit each parameter and select a different group
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
als Antwort auf: L.Maas
Thanks a lot for you reply.
So my understanding is that it would neither be possible to translate these groupings?
