Unless I highlight each one of these corner boards made with generic models, individually (can not "select all in project") am I able to hide them.
Can not find how to isolate them in VG.
Tried unchecking each sub categories individually and testing-no results, but when I uncheck "generic models, they go away, along with all generic models.
Does anyone know how to find them?
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Assign the geometry/detail elements to a Subcategory in the Family and turn that Subcategory off through Project's VGOs
Thanks barthbradley, but I have no idea where to start with that procedure.
Could you give me a hint as to how to start?
Thanks!
Open Family and go to Object Styles. There you can create additional Subcategories under Generic Model. Once created, select the geometry in the Family and look under its Properties for Subcategory and change it.
