Hidden Lines on Stair Section not Showing
3 ANTWORTEN 3
Nachricht 1 von 4
BigPicture045
275 Aufrufe, 3 Antworten
The stairs wrap around a pillar and the C-Channal Stringers along with the Treads are not showing up as hidden lines. You can see that the railing is coming through though:
Show hidden lines is set to ALL and adjusting the Far Clip Offset is not showing any difference:
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: BigPicture045
Change Far Clip Offset value so that it cuts the stair but does not go beyond it and use Clip with Line.
Nachricht 3 von 4
BigPicture045
als Antwort auf: ToanDN
[image: image.png]
Unfortunately, there is no change. I was thinking it must be related to the
C-Channel Stringer and Treads, but the bottom Stair is precast and does not
show hidden either.
Nachricht 4 von 4
