Hidden line model display showing in colour on linked model
5 ANTWORTEN 5
Nachricht 1 von 6
2622 Aufrufe, 5 Antworten
just trying to figure out why this model is displaying the colour of walls/roofs/columns in the hidden line display setting with no graphic overrides. this is occurring in plan and section views.
this is in Revit 2020. thanks
shaded viewshaded viewhidden line viewhidden line view
5 ANTWORTEN 5
Nachricht 2 von 6
ennujozlagam
als Antwort auf: Anonymous
Check if there is a view template assign to that view? and set to none. Thanks
Nachricht 3 von 6
als Antwort auf: ennujozlagam
it is happening in all views - there area no view templates set to them. cheers
Nachricht 4 von 6
ennujozlagam
can share some part of it so we can check? thanks
Nachricht 5 von 6
If a material has the surface pattern set to a solid color then it shows like that in hidden view.
Nachricht 6 von 6
martijn_pater
Yes, it's likely that. Check model overrides first probably. You can uncheck visibility for surface patterns here in your view (template for your elevations). Perhaps it could also be that the linked file follows host/linked view settings I think. You could check (custom) revit links settings under VG settings. But most likely the other one.
