Hidden Line Color
3 ANTWORTEN 3
Nachricht 1 von 4
1452 Aufrufe, 3 Antworten
Hidden Line Color
Hi there,
I have a question and issue with setting hidden line colour.
I used the Line Style settings to turn the Hidden Line to grey, but it did not work when the Properties "Show hidden line" option was By Disciplines. However, when I set the "Show hidden line" option to All, all was fine. How can I change Hidden line colour when it set By Disciples.
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: Anonymous
@Anonymous
Change the Hidden Line Style under the relevant categories
Nachricht 3 von 4
So you changed the color of <Hidden line> under Line Styles?  If so,  use the Linework (LW) tool to apply the Line Style.
Use the Linework Tool | Revit 2016 | Autodesk Knowledge Network
Nachricht 4 von 4
@Anonymous wrote:
Hi there,
I am pretty sure you need to change <Hidden Lines> for Categories via Object Styles (if you want a global change) or VG (per view).
