Hidden Basement
3 ANTWORTEN 3
Nachricht 1 von 4
cftnt
360 Aufrufe, 3 Antworten
Hidden Basement
Hello everyone, how can you visually hide a basement in a 3D view and allow the first and second floor to be seen?
3 ANTWORTEN 3
Nachricht 2 von 4
constantin.stroescu
als Antwort auf: cftnt
Use Section Box
  • Right click on the Wheel of the Cube
  • and choose Orient to View> Floor Plan. Chose the Floor plan of the Level you want to see in the Section Box. If you want to see two stacked Level , then increase the View Range Depth to the Lower Level that you want to appear in Section Box
  • Restore the Viewpoint either using Cube or Orbit
  • Section Box with two Levels by View Ranged increased
Constantin Stroescu
Nachricht 3 von 4
ennujozlagam
you can use the section box in the properties and adjust to suit your needs and hide in view the section box. thanks
Nachricht 4 von 4
how would both the first and second floor be seen in 3D if the basement was hidden?  I can't visualize. Are you asking about Exploded Views?
