Herringbone tile pattern on slanted wall in elevation
2 ANTWORTEN 2
Nachricht 1 von 3
236 Aufrufe, 2 Antworten
I have an angled wall which I've painted a herringbone tile pattern on.  There is a small portion of wall that is angled and the scale looks skewed and odd.  Any ideas on how to make this read a bit better?  I've posted an image for reference. Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
Lachlan-JWP
als Antwort auf: Anonymous
If the patterns looks fine in perspective views and when viewed perpendicular, then you may have to fudge it with a filled region over that part.
If the pattern still looks skewed when viewed in it's own elevation or perspective then check that it's the same pattern being applied (maybe someone painted the surface with a duplicate material).
Nachricht 3 von 3
You image resolution is very low to judge.  But if the wall is angled then its surface pattern is supposed to be skewed.  Nothing is wrong.
