I have encountered this problem and figure this out. Pls, help. The problem is I have to make this symbolic line for my door swing to move a certain degree angle but when I try to rotate...It says this.
Host your element to a Ref. Line Workplane that moves.
There's the gist of it:
Reference LINE (Reference PLANE is a different animal).
Align and lock the TIP of one end of the Ref. Line to the intersection of 2 Ref. Planes. Then make the Ref. Line the Current Work Plane and draw your Line Work on that Current Work Plane. Get it?
It all about Work Planes. Start here and drill down:
See if you can reverse-engineer this bad boy.
See Parameters for "W" and "A". I have know idea what drives the door width ("W"). I suppose you will get around to creating a Parameter that controls that. When you do, that Parameter will drive "W". Regarding the Opening Angle ("A"); play with different values from 0 to 90 and see the magic happen.
Dang it! I don't have access to a 2018 Workstation right now. So, you don't have 2020? Just to examine the file?
..I'll see what I can do on my end.
2018 attached.
Follow what I said in Message #5.
