Help with texture cutouts
2 ANTWORTEN 2
Nachricht 1 von 3
CT36801
202 Aufrufe, 2 Antworten
I am trying to load in a cutout map that looks like this:
this is the result in the texture editor and applied to the material, behind:
How do I remove those bars at the frame of the sample? why does the alpha channel appear correctly in the preview (With black squares)?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: CT36801
I don't understand what you are doing, but this is how I would approach...
Nachricht 3 von 3
handjonathan
Hi @CT36801
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
