Help with texture cutouts
2 REPLIES 2
CT36801
158 Views, 2 Replies
I am trying to load in a cutout map that looks like this:
this is the result in the texture editor and applied to the material, behind:
How do I remove those bars at the frame of the sample? why does the alpha channel appear correctly in the preview (With black squares)?
2 REPLIES 2
in reply to: CT36801
I don't understand what you are doing, but this is how I would approach...
handjonathan
Hi @CT36801
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Forma Design Contest
