After my adventure moving the whole building today, this should be an easier one. every time I try to adjust the ramp landing to how the red lines are shown, it fails to rebuild. is it possible to do it like this?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@cbt990 wrote:
How did you achieve that?
The key is to draw the ramp in a way that the runs meet exactly from the get go. If they don't meet and you need to move a run then it will fail.
To do that you may need to:
- create some guidelines before hand if you draw the ramp using runs and landing
- or, draw the ramp by boundary sketch, not runs
However, for a cleaner rail transitioning (both in Revit and fabrication), it is advisable to NOT have the runs meet exactly at a corner, and have landing extension on one or both sides.
