Help with Parametric Shading Facade in Dynamo
4 ANTWORTEN 4
Nachricht 1 von 5
926 Aufrufe, 4 Antworten
Hi everyone
I am very new to Dynamo and am trying to make a sun based moving façade like the Al_Bahar towers but with square based modules instead of triangles. I am having trouble with the Dynamo script showing what I want it to show. I've been basing the components off of youtube tutorials of the Al-Bahar towers and I just can't figure it out.
I am using Revit 2021 with the newest Dynamo version I believe.
https://www.youtube.com/watch?v=Bwwm13BT6kk&t=2319s
I hope I explained this decently.
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: Anonymous
It would be better if you supplied the Revit project and the dynamo script. Than we can have a look what you have sofar.
And be more speciific than "I just can't figure it out". So where are you stuck exactly
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
als Antwort auf: L.Maas
Here are the files that i've been working with.
Nachricht 4 von 5
L.Maas
Some tips to get you going
They are working in the massing environment, not in the standard project environment
File > New > Conceptual Mass
This results in some nodes not working
This node is probably not needed anymore due to Dynamo changes
Pay attention what the inputs asks. If it needs a plane than you have to give it a plane
Try to pick it up from here.
Louis
Nachricht 5 von 5
Thanks for the help before. That helped with the family modeling part of the project but I still can't figure out why the panels in the project view aren't working. The panels are made from the curtain panels family. Do I need to use a different type of family?
