I am trying to create a formula that multiplies an area parameter by a number. I am trying to calculate Net Square Footage for rooms by subtracting the area of casework ( a text shared parameter that is entered manually) multiplied by the number of casework (again, a manually entered text parameter) I am frustrated by the 'inconsistent units' error message that pops up all the time. Is there a conversion factor involved? Any words of wisdom would be appreciated.
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
text shared parameterthat is entered manually) multiplied by the number of casework (again, a manually enteredtext parameter) I am frustrated by the 'inconsistent units' error message that pops up all the time. Is there a conversion factor involved? Any words of wisdom would be appreciated.
the area of casework: needs to be an Area parameter
number of casework: needs to be a Number or Integer parameter
In Revit a parameter of type text is text and can not be converted to a Number or Area
Louis
Please mention Revit version, especially when uploading Revit files.
Sorry I wasn't thinking as I typed. Senior moment here....
CW Area - area parameter, entered manually into Room
Number of CW - integer. Also entered manually into Room
The desired end result is a schedule.
TY. In the meantime, the version that worked for me was
roundup(Area / 1 SF - (Number of Casework * Casework Area / 1 SF))
Strange. Your formula suggests that the Net Area parameter is Number, not Area.
