help with heating and cooling load anlysis
1 ANTWORT 1
Nachricht 1 von 2
165 Aufrufe, 1 Antwort
hello,
i keep getting issues when i try to generate insight on my building model.
i am trying to get the heating and cooling load analysis results for the location Accra,Ghana.
but i keep getting emails of failure.
Please help me .My project is due on Monday and if i am unable to finish it means i might not graduate.
i need to compare the heating and cooling loads on the same building built with concrete, brick ,and mud walls
that means i must compare the results of brick to concrete and mud.
here is the link to the building model.please help
https://www.dropbox.com/s/qexeere8n6qh0g1/CH%20building.rvt?dl=0
anyone who can help me please help.
the project is focused on the use of energyplus for the analysis
1 ANTWORT 1
Nachricht 2 von 2
Diego.Faria
als Antwort auf: Anonymous
From the analysis you mentioned and since you're short on time, you might want to consider running the Heating and Cooling Analysis using the built-in calculation tools in Revit, instead of Insight.
Just create copies of the file and change the materials you want, then run the analysis again and compare the results.
You can also export the gbXML of your project and use it in EnergyPlus with a few adjustments.
Diego Faria
LinkedIn
