Help with editing mass
7 ANTWORTEN 7
Nachricht 1 von 8
CT36801
431 Aufrufe, 7 Antworten
I am trying to split up the faces on this mass so I can push pull. I would like to split using a reference plane that is set at the canopy level. How can I start to break this up?
7 ANTWORTEN 7
Nachricht 2 von 8
vitorbortoncello
als Antwort auf: CT36801
Create another extrusion
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 8
CT36801
als Antwort auf: vitorbortoncello
Thank you. when I create a form using the profile of the existing extrusion, they are joined at the edge so I don't have true push pull functionality:
Is there a way to do horizontal push pull that leaves the proud edge and creates an inset edge?
Nachricht 4 von 8
CT36801
For example I am trying to push this face in without bringing the edge with it.
Nachricht 5 von 8
CT36801
I managed to get the right edit by creating a second extrusion from a drawn profile rather than Ctrl+selecting the edges and exruding that.
But I can't figure out why the behavior of the extrusions is so weird
Nachricht 6 von 8
CT36801
Also when I try to align the top blue face to the bottom blue face.. they dont actually align
Nachricht 7 von 8
CT36801
Just another view showing how the top box wants to slide outward as I move the bottom grip...
Nachricht 8 von 8
You can't.  You can create another Form from the base of that Mass. TAB-Select just the base and Create Form from it.
