Help with door
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
Szigeti.Eduard
952 Aufrufe, 13 Antworten
Help with door
I've created the attached door, but when I render it it looks very weird.
Please see attached files.
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: Szigeti.Eduard
I would just download Revit arched door families to Render until you can learn how model them properly yourself. In fact,  you ought download and study them to learn how to model them.  A number of manufacturers, such as Marvin, Pella and Jeld Wen, have arched door Revit families you can download directly from their web sites.  Check them out.
Nachricht 3 von 14
Szigeti.Eduard
Thank you for your message.
I went on their website and I didn't find any 3d models.
The only ones I found were just windows and in sketchup format.
I don't really want to model them, I just need one for my project.
Nachricht 4 von 14
serdar.erguen
Hi @Szigeti.Eduard ,
there is a "Surface smoothing" control for the exporter and LiveSync settings.
Unfortunately, curves are always translated into plane surfaces.
This setting should solve your problem
Serdar Ergün, BIM Manager @ Ed. Züblin AG &
Beitrag hilfreich? Dann gerne ein . Euer Anliegen konnte gelöst werden, dann gerne einfach auf "Lösung akzeptieren" klicken!
Gerne für meine Revit Idea "Flächenermittlung für alle Wandflächen" abstimmen
Nachricht 5 von 14
Szigeti.Eduard
als Antwort auf: serdar.erguen
Then what is the solution?
Nachricht 6 von 14
serdar.erguen
That your door has a round arch at the top and no jagged edges.
Or wasn't that your problem?
Nachricht 7 von 14
Szigeti.Eduard
Yes, this was my problem, but I still need it rendered round.
There is no way around it, I couldn't find a BIM model.
Nachricht 8 von 14
Szigeti.Eduard
In Revit looks good, but in Lumion not
Nachricht 9 von 14
serdar.erguen
How do you get your Revit model into Lumion? With the Lumion LiveSync Plugin or with an export?
Nachricht 10 von 14
Szigeti.Eduard
With the LiveSync
Nachricht 11 von 14
serdar.erguen
@Szigeti.Eduard look at this youtube video:
https://www.youtube.com/watch?v=DHJmvR1CqvM
this should solve your problem
Nachricht 12 von 14
Szigeti.Eduard
It did solve my problem.
Thank you
Nachricht 13 von 14
serdar.erguen
then you should accept my answer "as a solution" and not your own :leicht_lächelndes_Gesicht:
Nachricht 14 von 14
Szigeti.Eduard
Sorry
