For a Revit course I need to change the US Metric Library to the UK Library. I am having trouble setting the correct paths for the UK Library. I have downloaded and installed the UK Library. I have changed the default project templates to the US Metric which is the template I am going to use. I set the family template to English_I. When I select the places button and I change the library paths to the UK Library it does not work. I have made new libraries including a Metric Library and Metric Detail Library. I set them to the UK Library path.
The components from the UK Library are not there when I start a new project. When I select the Wall Command it does not show the wall types from the UK Library.
Walls are System Families and are created from within the Project Template. OOTB Project Templates (rte's) contain a few pre-built walls, but you can always add Wall Types by creating new ones, or by loading Wall Types from other Projects.
