Help: Winder stairs
Help: Winder stairs
hillierer
Observer Observer
Help: Winder stairs
hillierer
Observer
Observer
I'm trying to make these winder stairs in Revit 2025, 850mm wide from ground floor to first floor (2300mm) but everytime I sketch it, it's never successful. Is there anything I'm missing or doing wrong? Just can't ever seem to get stairs right on Revit.
It's also now showing odd riser counts...?
Ahmed_M_Heteba
Hi @hillierer
The joint shown here is not applicable in Revit stairs
1. You need to leave a small gap between the 3 connected riser lines marked here
2.The End of the stair should be a riser connecting the 2 boundary lines
3. The stair path must be cont. and connecting all risers in your stair
4. Prefer to draw any small run then convert to sketch afterwards
similar stair below attached
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
