Help! Why are stairs are visible through floor?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mail2hml
2297 Aufrufe, 2 Antworten
The cut lines are not visible and the base of the stairs on level 1 are visible through the floor structure. It only occurs on Level 1. I have checked the View Range and Visibility check boxes but all seems okay.
Tags (2)
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: mail2hml
It's difficult to tell from the image, but you can check:
Is wireframe on in the view?
Is the floor hidden, or does it exist?
Is the floor at the correct level? Check with a section.
Nachricht 3 von 3
mail2hml
als Antwort auf: Anonymous
Thanks, yes it was set to wireframe view which was annoying
