Help! Wall relief / depression
Good day! I want to know how to wrap my wall/Partition relief, but i see no option. This is 2014 revit as well. I've attached an image up and as you can see. Please help
Darin.Green
Have you look at the Assembly of the wall and make any attempts to build out the materials, sweep, and wrapping?
Select the wall, then use the Edit Type from the properties panel, then the structure Edit button within the Type Properties
In order for the sweep option to become available, you'll need to click Preview then Section: Modify type option for View
If this information was helpful, please consider using the Accept Solution
Yesss i have tried that. Even clicking the option to wrap only had the reveal* on one side, but I had just learned from a co worker another way of doing it. If there is another way of doing, please let me know! Thank you.
 Then she told me to modify the end and connect the reliefs.
Darin.Green
If you select the Reveal, the contextual tab doesn't display, use the toggle to cycle through the tab visibility:
