Help to create the wall for this facade
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Soytei
471 Aufrufe, 3 Antworten
Hi everybody,
I´d like to know how to create the wall for this facade with the notch.
I´m interested about what is the easyest way to create this facade.
Many thanks in Advance
3 ANTWORTEN 3
Nachricht 2 von 4
Sahay_R
als Antwort auf: Soytei
Model just one repetitive unit
Take this piece and array it to get the overall facade. Don't go overboard with the swoopy-curvy stuff - a lot of the detail can be added as detail lines. Model the porch on its own.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 4
Alfredo_Medina
If you need to model this you need to be good at making families. You need a wall, some 4 or 5 types of windows, some column families, 1 generic model family for the brackets, some reveals, some line-based families for cornices, etc... Everything can be done. The only part that cannot be modeled is the sculptures on top of the entrance. But everything else can and should be modeled.
Nachricht 4 von 4
Corsten.Au
Hi
You can use " Reveal " feature embedded in wall type..
use profile to have continuous reveal..
you can customise notch / reveal profile, height etc..
I have attached screen show and uploaded revit file as well.
Cheers!
Corsten
Building Designer
