Hi. I already wasted way to much time back and forth with this and nothing seems to work.
I just want to delete a total area of an only outside area so it's just doesn't seem duplicated.
Thank you so much in advance.
Gelöst! Gehe zur Lösung
Gelöst von vitorbortoncello. Gehe zur Lösung
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Yes I'm using sorting/grouping because I need the total of the inside area and the only the grand total area not the outside ones total (in this case only has one terrace)
create a separate room schedule just for the terrace
That might be the solution, just hoped there was a way to do it together
