HELP! Revit objects not showing
5 ANTWORTEN 5
Nachricht 1 von 6
mathea_anne_sadiua
351 Aufrufe, 5 Antworten
Hi! Can anyone please help me solve my revit problem? Whenever i open a revit file i dont see anything like the canvas is blank even if i zoom to fit nothing is showing but if a drag my mouse and select everything objects are selected but still cant see anything, even on elevations or other levels its blank I even tried to make a new file and still nothing. I think i uninstalled revit before and it was still like that. Could it be my laptop? Please helppp!! thank youu!!
Im using an ASUS VX15: intel i7 7th gen, Geforce 1050, 16gb ram.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: mathea_anne_sadiua
Are you Opening an existing RVT Project or an existing RFA Family, or are you Opening a New RVT Project from an RTE Template or a New RFA Family from a RFT Template?
If you know something should be there, then this cheat sheet might help you find it:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
Nachricht 3 von 6
mathea_anne_sadiua
als Antwort auf: barthbradley
Im opening an existing file and tried making a new file. The existing file works fine on other devices but not on this laptop.
Nachricht 4 von 6
So, it sounds like it is hardware related.  Maybe Graphics Card. Dunno. Not enough info to troubleshoot. You might want to open a support case on it through your autodesk.manage.com portal.
Nachricht 5 von 6
Tom_Kunsman
Delete your local file. Delete all Windows Temp files. Empty the recycle bin. Now try opening the file.
Nachricht 6 von 6
handjonathan
Hi @mathea_anne_
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley @Tom_Kunsman helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
