Help - Revit File Corruption Error
1 ANTWORT 1
Nachricht 1 von 2
210 Aufrufe, 1 Antwort
Please can I can get some urgent expertise on the following.
I've been working on a project in Revit and recently started to get corruption messages.
For instance, I was changing a material on a wall and the message occurred and offered me the option to save and recover the file. After doing this, I couldn't open the recovery file or any of the backup files that Revit automatic creates so I lost half a day's work and had to start again.
To try and avoid this problem again, instead, I kept "saving as" different versions just in case. However, closing Revit down at the end fo a days work, I came into work the following morning to open my latest version (V6) and the following message occurred "Data in File ****is corrupt and needs to be manually recovered. (I can still see the model as a thumbnail when you select the file before opening so the data must still be there)
Please can someone provide a solution to this as I have a deadline that I'm going to miss if I can't retrieve all the work I've done?
Any support would be very much appreciated.
Many thanks
Nat
1 ANTWORT 1
Nachricht 2 von 2
mpeperkamp
als Antwort auf: Anonymous
Hi @Anonymous,
Maybe this can help you:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-Data-in-Revit-file-is-corrupt-and-needs-to-be-manually-recovered.html
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
