Hi Revit'ers
We have a project where we have done our drawings in AutoCAD, XREFing a architectural background and then drawing our lighting atop it, and them use REVIT to bring together and plot everything. The issue we're having is draw order. Our lighting layers are brought to the front in AutoCAD and plot fine from there, however sometimes they drop behind the XREFs when we plot from REVIT. See attached images of a plot from AutoCAD where LP6-013 tag is above the XREF lines, and the REVIT plot where it drops behind.
Please help!
Maybe draw a section thru that area and make sure the CAD file is "below", above in the case of a ceiling plan, the cut plane.
Opaque Tags in lieu of Transparent Tags?
I see they are Opaque.
Do you have the "Foreground/Background" control available on the Option Bar when you select the imported DWG file?
...sorry. I meant to add: if you don't have "Foreground/Background" control, you can get it by selecting the "Current View Only" when you import the CAD file.
To specify element draw order
The following tools become available on the Modify <element> tab
Arrange panel.
