Help on linked topo surface
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
288 Aufrufe, 2 Antworten
I have linked a cad topo drawing.
Unfortunately the contours do not extend as far as I would like so I could pick up the existing footpath and road.
How would I edit the topo surface so that it includes the path and roads? I have existing spot levels.
Tags (2)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
You can edit the CAD file in AutoCAD and add more points based on the spot elevations to cover a larger area. Then reimport it in Revit.
Nachricht 3 von 3
als Antwort auf: ToanDN
Yeah that worked thanks.
