HELP Nothing visible on Revit , Model seems invisible
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
3810 Aufrufe, 9 Antworten
Hi fellow Revit/BIM mates,
I need some help in regards to this issue that I have now on Revit as I am currently facing a deadline for the final model in 2 days time. Really appreciate it if anyone can help me out!!
Issue:
I was just working on my model few days back and suddenly today the entire Revit turn blank (picture 1) after I have decided to save and reopen the file. Everything else can be seen like properties box and things like that. Anything other than the model (which includes all the grid lines and section and the 3D icon box that can usually be found on the top right hand corner of a model in a 3D view) can be seen. Tried drawing and modelling on Revit itself, nothing shows up too. Zoom to fit doesn't work as well. It is as if that the model for Revit is invisible. All the information on the drawing is invisible because when I hover my mouse over, I can totally see that the item/model is there (picture 2). All shortcuts worked fine and visibility is checked. I do not know what is wrong..
What I have tried doing & didn't work:
-Opening a new Revit file (new model & new family creation) , nothing shows up. Gridlines for Ref view can't be seen as well.
-Restarting Revit by closing all Revit related files and opening them again
-Select all of the items in the model, delete it and undo.
-Update Windows software
-Restarting my computer
-Search Visibility settings (but all the setting is in order)
-Update Java
-ZF function
-Drawing a model and nothing shows up, no line, no nothing
Would really appreciate any kind soul to help me on this. If you have ever encounter this problem and solve it please help out a fellow Revit mate!
Thank you in advance!!!!
9 ANTWORTEN 9
Nachricht 2 von 10
ennujozlagam
als Antwort auf: Anonymous
check your phasing setting and see if helps thanks
Nachricht 3 von 10
als Antwort auf: ennujozlagam
Thanks for the speedy reply @ennujozlagam  but unfortunately, it is not the issue.. the filter setting is in order.
Nachricht 4 von 10
ennujozlagam
can share the file so we can check or activate the bulb icon in your lower left corner of your screen it could be all hidden and check your VG if all are tick. thanks
Nachricht 5 von 10
Hi @ennujozlagam ,
Here's the link of my model file. I have a strong feeling that it may be software issue though cause all of my Revit files are displaying the same way. Inivisible. Not sure why.. The reveal icon doesn't work. VG all checked too..
Link : https://we.tl/t-pf4s5hKmun
Thanks so much for your help!
Nachricht 6 von 10
ennujozlagam
i change your file from rte to rvt. see attached. untick your use hardaware acceleration from options and see if helps. thanks
Nachricht 7 von 10
ennujozlagam
untick your use hardaware acceleration from options and see if helps. and update your graphics card driver to the latest and install latest updates from autodesk. thanks
Nachricht 8 von 10
aRcHiTeCt.JM
... hi @Anonymous
... there is nothing wrong with your file
... the issue must be with your pc
... try cleaning the pc with ccleaner
.... delete all temporary files
.... turn off the restore points
.... if this is not working as well
... try reinstalling REVIT
... and next time try not to design the project directly into a template
... save it as a project
.... (well... unless you want it as a template for future projects)
... by the way
... this structure looks very nice, very detailed
... this analytical model is very cool
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 9 von 10
@ennujozlagam Thanks for this, updated Autodesk services and extensions and worked very well!!!
Nachricht 10 von 10
als Antwort auf: aRcHiTeCt.JM
@aRcHiTeCt.JM Thanks for the kind compliment! Tried updating the extensions from autodesk desktop app and its working great now! Thank you so much for the help though! ^.^ appreciate it alot!
