HI IM CURRENTLY USING REVIT 2017
I HAVE MY WINDOW AND DOOR TAGS LOADED AND ASSIGNED.
MY PROBLEM IS THAT IN ANY VIEW MY WINDOW AND DOOR TAGS ARE FINE
BUT AS SOON AS I GO TO PRINT PREVIEW OR JUST TO PRINT HALF OR MORE
OF THE W OR D IN MY TAGS WONT PRINT AND I DONT KNOW HOW TO SOLVE THIS
IVE ADDED SOME SNIPETS IF IT HELPS
THANKS FOR ANY HELP
VANESSA
Gelöst! Gehe zur Lösung
Gelöst von FAIR59. Gehe zur Lösung
Hello@Anonymous
Sorry but It's not clear if you have problem with half of all view or just with tags? .. your screenshots show just half of print preview or any view I need to see all of view so that I can help you ![]()
-Best regards
-Ahmed
HI AHMED
THANK YOU FOR YOUR HELP
IM UP LOADING FULL SNIPTS OF MY FLOOR PLAN AND ONE OF MY ELEVATIONS AS WELL AS THE PRINT PREVIEW
Hi..
Try this for a while..
Just Print " PDF " in both Vector and Raster settings.
Print Preview is usually just to show the setup,its not the final print..
so don't rely for details in preview, all details will get printed in final PDFs..
Cheers !
Hi
For Window tags, can you edit them and make the test " transparent"
1. Edit the tag
2. select the text and change "opaque' to "transparent" in the properties
3. load that family back to the project.
( You can always upload the window tag family here, if you want someone to fix it "
hope this will help you.
Cheers!
HI TOANDN
IM USING ARIEL IVE ADDED A SNIPET
MANY THANKS VANESSA
HI GANESH
I HAVE PRINTED TO PDF IN BOTH VECTOR AND RASTER
BUT I'M STILL HAVING THE SAME PROBLEM.
MANY THANKS VANESSA
HI GANESH
I HAVE TRIED YOUR OTHER SUGGESTION OF CHANGING THE
TEXT TO TRANSPARENT INSTEAD OF OPAQUE AND LOADED IT BACK INTO THE
PROJECT AND THEN I HAVE PRINTED IT TO PDF USING THE VECTOR PROCESSING
BUT IT STILL HASEN'T RESOLVED MY ISSUE
MANY THANKS VANESSA
I think the problem is, that your text-label and number-label overlap.
in the family set Horizontal Align to [Right] for your text-label, and make sure the borders don't overlap
( alternative: put the text and number in 1 label, separated by a space.)
THANK YOU ALL FOR YOUR HELP IT SEEMS THAT THE TEXT BOX WAS CUTTING HALF OF THE LETTER OFF
THANKS AGAIN SO VERY MUCH APPRECIATED FOR EVERYONE'S SUGGESTIONS AND HELP ![]()
MANY THANKS VANESSA
MANY THANKS VANESSA
and it only cut off letters W and D, not any other letters? Sounds strange.
