Help needed for Toposolids option in revit (CSV points)
7 ANTWORTEN 7
Nachricht 1 von 8
sodenkhangsarpa
462 Aufrufe, 7 Antworten
Hi, so when i was using the feature of creating topography from the csv points (in meters) i got a very weird single line as a product. Now as far as the Csv lines are concerned they seem accurate as I've even exported it to autocad as well, some please helpp :')
sodenkhangsarpa_0-1703605935432.pngsodenkhangsarpa_1-1703605977080.pngsodenkhangsarpa_2-1703605998495.png
These are the points for reference
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
hmunsell
als Antwort auf: sodenkhangsarpa
without actualy having the file, its a guessing game. would you be able to upload the model and the associated CSV file for us to look at? even just the CSV would help :-).
Howard Munsell
Nachricht 3 von 8
Looks to me like you have a single point placed at 0 elevation by accident. Modify Sub Elements and remove it.
You're welcome to post both the RVT and CSV here for us to examine.
Nachricht 4 von 8
sodenkhangsarpa
als Antwort auf: hmunsell
Hi, thank you for your reply, I've posted both the revit and CSV files below
Nachricht 5 von 8
sodenkhangsarpa
als Antwort auf: barthbradley
Hi, thank you for your reply, I've posted the revit and CSV files below
Nachricht 6 von 8
Your points are on top of each other!  Each of those lines in the Point File represent the x, y, z coordinate of the Point. You've got points placed 0.0000X apart from one other.
Nachricht 7 von 8
sodenkhangsarpa
how do i correct this?
Nachricht 8 von 8
I suspect those are Latitudes and Longitudes in your Point File.  You need to convert all 2328 lines to Northing (y) and Easting (x) coordinates.
https://www.earthpoint.us/BatchConvert.aspx
