Help Modeling
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
markolukicbing
670 Aufrufe, 10 Antworten
Help Modeling
Hi can anyone give me advice on how i would model this facade element.
Its a thin epoxy and fibreglass shell that's hung on steel frame.
10 ANTWORTEN 10
Nachricht 2 von 11
blank...
als Antwort auf: markolukicbing
A sweep with a void.
Just one approach, there are probably dozen more.
See attached "Sweep".
You can then use it as a curtain wall panel and create the entire facade like that.
See attached "CurtainWall".
Another approach would be making it as an adaptive component and use divided surfaces in massing environment, which is a little more involved to make, and explain.
Nachricht 3 von 11
markolukicbing
I was wondering if there is a way to make it a thin shell instead of a full solid form, i need to place structural frame on the inside?
Nachricht 4 von 11
blank...
In short:
- start with an "Curtain Panel Pattern Based"
- create a curtain panel family
- start a mass, create the surface, divide the surface, apply the new curtain panel.
- import into your project.
End up with something like this.
Like I said, not an easy thing to explain. Here's this example if you want to dig into it, but without knowing the principles it's probably not much help.
Btw, judging by your username, rekao bih da se razumijemo :grinsendes_Gesicht_mit_lächelnden_Augen:
Oh, and there is a real possibility I'm massively over-complicating this. You could also go with the first approach of regular curtain panel and wall, and jsut add several more void forms in panel family to create the shell.
Let's wait what others have to say.
Nachricht 5 von 11
narsimhamurthy21
You can make it with adptive components.
here is the vide reference.
https://www.youtube.com/watch?v=WjrrNCoB7yM
Nachricht 6 von 11
Sure, but 1/32" is the minimum thickness.
Nachricht 7 von 11
markolukicbing
als Antwort auf: narsimhamurthy21
This looks promising I'll try using these methods.
Nachricht 8 von 11
markolukicbing
als Antwort auf: barthbradley
That's fine i need it to be around an inch thick.
Nachricht 9 von 11
markolukicbing
Thanks, it took a bit of time but this method gave me the result i was looking for.
Nachricht 10 von 11
narsimhamurthy21
You're welcome! I'm glad to hear that the method I suggested helped you achieve the desired result. If you have any more questions or need further assistance, feel free to ask!
Nachricht 11 von 11
HVAC-Novice
Not sure if this can help:
https://www.youtube.com/watch?v=Lnh6DE31xDE&ab_channel=BalkanArchitect
Revit version: R2025.4
