Help me set my RCP view Range Please
10 ANTWORTEN 10
Nachricht 1 von 11
ALIGNIAD
469 Aufrufe, 10 Antworten
Hey guys. I have a sloped ceiling and I can not set my view range so that I see everything I need to.
9' on the low side and about 13' on the high side. I want my door swings and clearstory windows to show. Doors are 80" Tall.. Window sills set at 6'5"  - SEE SECTION attached.
I created a View Template - underlay Orientation is " Look up" but no matter how I mess with my range settings I cant see everything I want to at once. I have seen the drawings explaining how range settings work with RCP. I have tried to set accordingly and it doesn't work. Can someone recommend a setting for my situation so I can try and see if it works. Thanks!
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: ALIGNIAD
You can cut both the window and door in RCP.  What's with the underlay?
...does this help?
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-D...
Nachricht 3 von 11
Set the cut plane at 6'-7".
Nachricht 4 von 11
als Antwort auf: ToanDN
...or somewhere in-between 77" and 80".  How 'bout 78-1/2""?  That's within the 3" zone.
...or maybe this has nothing to do with Project View Range Settings. Maybe this has everything to do with Visibility Settings of the Family.  I mean, I am still trying to wrap my head around what the OP is trying to do with an Underlay.  Sounds like it's an attempt to force something to be visible.
Maybe the solution is a Plan Region. Dunno.
 Create a Plan Region | Revit 2021 | Autodesk Knowledge Network
Nachricht 5 von 11
ALIGNIAD
als Antwort auf: barthbradley
I know that I can - but I cant seem to cut them and also see my full sloped ceiling.  I added a snip to show you what i meant by underlay. Ive tried it as "looking up" and "looking down" it changes nothing
Any recommendations for my range setting?
Nachricht 6 von 11
ALIGNIAD
See attached. at 6'7 nothing shows. If i set it to 9' 1/2 my ceiling shows.
Nachricht 7 von 11
When all else fails, Top="Unlimited" usually does it.
BTW: How can you tell you aren't viewing the bottom of the ceiling? Are you trying to tag it with a Slope Anno and it fails?
Nachricht 8 von 11
ALIGNIAD
I have top set to unlimited and view depth level set to unlimited. See attached images above for my settings
Nachricht 9 von 11
ALIGNIAD
I have my ceiling set as a 4x4 ACT so I can see it when it when I cut it. If you look at my attached snips above you will see when I set my cut to 9' you see 1/2 of the ACT ceiling
Nachricht 10 von 11
Those screenshots don't help without a reference. I don't have your model in front of me.
Nachricht 11 von 11
Just post your RVT.
