Help me achieve polycarbonate render look?
3 ANTWORTEN 3
Nachricht 1 von 4
9323 Aufrufe, 3 Antworten
I am trying to achieve this look with white polycarbonate:
Material 1. I tried creating a new custom material from a previous plastic material but it was not possible to control the transparency, because there was only an option for 'Transparent Plastic' or 'Solid Plastic.
Material 2. Then I created a new custom material from a previous metal material, but in this case when I turned on transparency the wall turned completely transparent despite the construction of the wall being composite (polycarbonate+insulation+mebrane+plaster+concrete+plaster).
I have attached the 2 materials I described and a bump map.
Can you suggest how to create the material shown in the first picture and what settings (glossiness, reflectivity, transparency, translucency, bump, tint etc)?
3 ANTWORTEN 3
Nachricht 2 von 4
L.Maas
als Antwort auf: Anonymous
What you can see is that Revit, to simplify/increase performance, treats the wall as a single layered object.
See what happens when you look at the same wall from two different sides.
So for rendering purpose I would put the polycarbonate layer as a separate wall and see how it goes.
Revit has already some polycarbonate materials.
I would use one of those as basis for your material
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 4
Select the wall and use Create Parts.
Change the View's Parts Visibility to Show Parts.  You now can render the wall with different materials for different layers.
Nachricht 4 von 4
als Antwort auf: L.Maas
Dear Maas, in my revit library has no polycarbonate-smoked material, i have searched from the internet also, but i could not find, i need this materail urgently, could you hep me ?
