HI, I can't seem to add cedar shakes to this model, I'm doing for school.
Any help would be really appreciated.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
You have to duplicate the material. Click on this and select the asphalt material
Duplicate the material
Click on the material browser and search for shake and double click on it.
Go to the graphics, set to "USE RENDER APPEARANCE". Click on Surface pattern and choose Model> Shake 6"
Result.
I'm also having trouble seeing the plans on their levels! I've tried using Phasing but that doesn't seem to help, only confuse. @syman2000
Plus I can't seem to edit the cut fill (its drawn at the interior of the foundations and not at the exterior faces)
Currently I am trying to revise the exterior walls to be Stone or wood at both interior and exterior faces.
Sooo much fun! ![]()
Currently your project have a lot of phases. You may want to select the latest phase to make your object shows up.
If I set to show complete, the building shows up
Also if you want to show the topo hatch, you have to click on the setting and change the material to earth. Make sure you change elevation of poche base to -30'
If you have to cut a hole for basement, you have to use building pad.
